180pto slipping
Hydraulic PTO,2speed PTO had new seals on piston,the two orings and sealing ring in end cap.reused plates.looked good not warped. Go out brushing and will cut 12tall weeds fine hit some tall grass and stops the mower. Raise mower up and slowly will take off again and cut the shorter grass.tall grass stops it. I have Allis book and it manuals and not much in their for trouble shooting. Help.not sure if pressure or valve or plates.
If everything is right, that clutch was transmit 100 or more HP without slipping. Pressure check is done at the manifold that the brake latch is fastened to. Check pressures in low and high side of the power director clutch and then check again with PTO engaged. Should be more than 250 psi.
Ok pressure is at 225 , pressure doesn't
change when PTO engaged and when brush
hogging thru tall grass. Is their a after
market place for plates and discs for those
ptos?
