BUSHNELLMAN
I am trying to put the shift tower back on the transmission for my 39 wc. i've lubed up the shift rods and been trying to figure out what position the gears in the transmission housing are suppose to be when in neutral.
my shift lever seems as if it has no physical connection to the forks or the shift lugs.
the transmission was full of water and froze, and I had to repair the cracked housing. I had the transmission out of tractor and had took the tower off, and now i need to put it back together. (the tractor has set for 20 years) and i know that the kids were up on it trying to "shift" it when playing on it in winters past so i don't know, and i cannot see anything that is broken.
any suggestion will be appreciated! thank you
