Re: AC 5040 STEERING
I have been searching the Youtubes and the forums for some ideas for refitting my steering.
Basically the steering wheel has almost a full turn before you get any movement of the wheels. I have reviewed parts needed in order to rebuild the steering but think it best to replace existing with new.
I have a small front end loader that will fit the tractor with a little welding and some rigging. The front end of the machine is not real beefy, I understand to keep the loads small so as not to bust anything.
I will need to add the hydraulic control for the FEL with that I could pipe in some lines to a orbital steering valve.
The tractor currently has hydraulic power steering.
Looking for a place to source the orbital valve or any ideas where I can buy something used that I can rig to make work?
If I get the valve installed do I add a cylinder or two to the front end to move the wheels or tie the valve into something existing in the steering components.
I have pics with notes on them. Working on how to post them
Thank you for reading and any ideas that you can share. The machine was my grandfathers or it would be replaced with something new and green with a cab and air!!
Nate from Franklin, Indiana
