Plz help wd45 hydraulics
Dustyah
So the hydraulics on my 45 raise as soon as tractor is started, won't release, removed rockshaft to eliminate any binding linkage issue. Won't lower over time, bleed down, Checked all linkage, set per second image, plates locked together, lower plates locked to case, lower screw,on front side, all the way out, no change, swapped hold valve off top from parts tractor, no change, removed linkage from bell connect, no change, I'm assuming I'll have to pull the pump, looks like no fun, what are your thoughts
