WD45 brake lining replacement - need advice
JRB.ACWD45
New User
Should I use a cutting torch to remove the anchor pins accessed at the lower casting hole as the pins are both stuck? Any other ideas? Also, when replacing, can the brake shoe front and back assembly be put together with the anchor pin and fished down around the brake drum using wire rather than trying to install the lower anchor pin through the housing casting hole? Thanks, JRB
