I'll try to be brief but descriptive. I bought an Allis 6060 FWA, The PTO clutch (right side of tractor) is stuck in the engagement position. As the manual states if you want to use the PTO, prior to starting tractor engage pto first. After tractor is started and you want to use the pto move the pto clutch lever forward. Right now if I want to use the pto I engage the pto lever but it starts turning when the tractor starts. I took off all the linkage from pto clutch lever under right side of tractor to see if I could move the actuator by hand. The actuator will move slightly but you can tell its hitting something inside. I even (with tractor off) put a small chain on it and tried to pull it to the off position but to no avail. Does anyone know how to fix this or what I have to do? Do I have to split the tractor or is there and easier fix? Let me know if there is any other information you need to give me your two cents... I sure do miss my D17's and how easy they were to work on..Thanks for any info...
