AC 66 Header
Well, my dad was a dealer and I took many of those off the rail car and assembled them. After 65 years, I'll try to think this through in reverse. Unscrew the tension bolt and release the large coil spring under the header, disconnect the header lift mechanism be it lever style or hydraulic. The upper roller for the lower draper has to come out so remove the pulley which drives the sickle, take the lower draper loose, any parts retaining the roller, by then you will see what is left to remove. This is not a one man task.
