Allis C hyraulic lift arms seals
rcfarms
Looking for seals/ packing seals for my leaking Allis C twin lift cylinders. The rod is 3/4" and OD is 1". I couldn't find any on the AC sites, and idea where the seals might be found? Thanks, Ron
You can look up the part number on AGCO parts web site. You can first tighten the packing glad to keep it from leaking. Any good hyd shop should be able to get them. Sandy Lake Imp is an AC dealer that can probably get them for you.
AaronSEIA
I tried to locate the C hydraulics info at the AGCO site but was unable to find anything....probably me not knowing how to find it.
Checked at the MFP site, they had the packing for VP0750X1250V, but was unable to find the male or female adaptors/part numbers. Called and they first said they no longer carried the parts but would check the warehouse, didn't hear back. Their pricing seemed reasonable compared to others.
Unless the existing M&F adapters are significantly damaged, they probably can be reused since the actual sealing is done by the v-rings and not the adapters. The adapters are there to provide even pressure without distortion of the v-rings during tightening of the gland nut as needed to prevent leakage.
