Mike in Ohio
How much free play should there be in the distributor on a WD45? The timing is jumping all over the place. With a timing light the fire mark is lighting up an inch on either side of the center of the hole in the bellhousing. No real pattern to the swings. Seems like the rotor has a lot of play.
Also, what brand of ignition parts do you guys use and where do you get them? I have using NAPA or tractor supply, haven't been having good luck with either lately.
Thanks
Thanks
