No, its not running.
1. Does anyone KNOW for certain, and without reservation that a 9.00x20 M&S traction tire will fit on the back and not touch?
2. WD engine crankshaft main and rod bearing std journal size? I'm going to need to go .020" under, and the bearings are avail here, but we need to know what to grind to, so need the factory journal std sizes to start.
3. What lube should I put in gear boxes. What lube in transmission?
4 Will be operating at 8400-9600' elevation, and need some power. I'm thinking of using that bolt on turbo setup to get me more mani pressure at that altitude. Opinions? Theories? Guesses? I was going to go up one size on the main mixture, but at that alt and with turbo-normalizing back to ~sea level, I'm thinking maybe just leave it alone, and tune carb and timing for best power.
