Jim Hilbrand
New User
I have AC WD problem with hydraulics. When tractor starts the 3 pt. arms raise but I can't get them to go down. The arms raise even with lever in the down position. I previously had the loader attached with blade for snow plowing. This worked perfect. I removed the loader now want to use the 3 pt.
Any ideas where to start trouble shooting? It appears pump works but is there a check valve or something that may not be releasing?
Thank you for any help. I'm not a mechanic FYI.
