TractorLinks.com
Show Parts for Model:
Re: RE STUCK TIRES
DrAllis
05-16-2018 13:59:51
If I was going to try to unseized it, I'd do it like this. Refill with at least 7 gallons of hydraulic/transmission fluid. This would require filling thru the two square headed fill plugs ( one just ahead and the other just behind) around where the clutch pedal is. You'll get a total of 4 gallons in thru the plugs. Then for the last 3 gallons, I'd remove the rubber boot and snap ring from the gearshift and pour the rest in thru there. Pull the gearshift out when in neutral and don't lose the square headed side pins!! might only be one but could be two of them. Get gearshift back installed and start the engine. Try to get it to break loose in low gear and maybe reverse. If it frees up you are a lucky man. I'd leave it jacked up in the air to do all this.
