B engine mag to distributor
What all is involved in swapping a magneto out for a distributor ignition? The B engine has the mag and I have access to a parts CA engine I could get all the distributor parts from. I'm sure it would involve re timing the engine. Is this something a novice could tackle? Thanks.
Not all that hard to do. Just be sure you have #1 cylinder at TDC on the fire stroke and then take the mag off and also make sure you know which nipple on the cap of the distributor will be the one that lines up and then put the plug wires on correctly as in 1,2,4,3 firing order.
