bisenberger
New User
I got my Allis C back in running order. It ran good the first time out, nice and smooth for about 15 minutes. The second time it would run and then stumble like it was not getting a steady flow of gas. It set for about a week. I tired to start it. It cranked and cranked. Started and ran about 20 seconds then died. It won't start. It cranks until one cylinder fires and then kicks the starter out. I thought it was my needle and seat not shutting off. Fuel was dripping out o the bottom of the carburetor. I disassembled the carburetor and found grit in the inlet ahead of the needle and seat. I cleaned the carburetor and put a kit in it. I also added an inline fuel filter. Stills cranks but will not start. I check the plugs and they look dry.
Is there anything else to check
