Hood & weight bracket
Getting loaded up for a swap meet and I have a few Allis parts I need help with. Have a Lt hood for a d-15 or d-17 I think. It’s 26 1/2” long. Also have a suitcase bracket my grandpa gave me, he thought it came off his 190xt or 200. It has 3 bolts to mount it to frame rails and has 6 square holes weights fit in. I just want to make sure I can tell people for sure what they fit. Thanks for the help!
Sounds like a bracket for a 200
Thanks Eldon! That is it. Is the 200 the only tractor it fits? Does anybody have a d-17 or 15 they can measure the hood? Thank you.
Hood is much longer than that on a D15 or D17. If you mean the Radiator Shroud, a D14 shroud is 26 1/2 tall, D15 is ~28 tall. I have all so please clarify what part the the 26 1/2 applies to. Cant be the hood. I couldn't find anything else that the 26.5 could apply to.
Its the hood that says “Allis Chalmers” on the side that is 26 1/2” long. It’s a 2 peice hood this is the right side.
I came up empty, a D14 hood is 36 1/4, D15 is 39 3/4 and I didn't even go to the barn and check out the 17 since it's way longer. The D10/12 hoods are 30 inches but they aren't split. I took a look in the parts manual and the stationaries don't appear to use split hoods. I'm interested in what it is, in fact, it sounds like the type of oddity I like to put on the shop wall.
One thing I don't have here at the moment, is a Parts manual for the larger stationary engine based on the D17. Maybe that's it?
The photo shows D14, D15, and though obscured D10 and 12 in the background.
