Lumbersawyer
- Location
- Grand Rapids, MN
I need to switch my transmission on my 37 WF. It looks like I need to either remove the engine or the rear end. The steering box is bolted to the top of a tubular housing that runs between the bell housing and rear end. I don't think a WC is the same as the WF, because the WF is shorter and the steering is different. What in your opinion would be the best way to change the tranny out? My transmission is cracked from freezing with a little water in it. There is no exposed drive shaft or u-joint that I can see.
I found a nice used tranny that has the same casting dates as mine. It is the last major thing left on my WF to get fixed.
