AC WD45 Restored Tractor Pictures
JRB.ACWD45
New User
My son and I are beginning to restore a 1955 WD45, 6-Volt, WF. I am in need of receiving detail pictures from fully restored tractors showing different views of parts and locations to understand how components of a finished product are routed and connected. For example, we need to replace the gas tank support with light bracket. There are two holes on the bottom of the bracket. A picture from a restored tractor showing what pieces goes up into those 2 holes, presuming either the main wiring harness or two wires, one for each 6-Volt light, or Traction Booster line, will be fantastic. Another picture I need is of the small round clamp, about 1/2" Dia. and whatever it holds..??.. that is attached with a short bolt, on the underside of this same tank support bracket. There are many great pictures on the internet, however, very few that show the restoration component details. Your help will be appreciated. If you are willing to help, please send pictures to my email. [email protected] Thank you, Jim
The Traction Booster line does not go thru the gas tank support holes. There is a single wire from the harness that goes into one of those holes, and both single wires from the lights are attached to that wire. The connection will be made inside the tank support. There is a two-piece holder that attaches the Traction Booster gauge to the tank support, with one bolt.
(quoted from post at 12:14:56 04/12/18)
JMS/.MN: Thank you very much for the information and your quick response. That is very helpful. The tractor is in several pieces. Jim
Thank you very much for the information and quick response. That will be very helpful. The tractor is in pieces. Jim
