Leonard Dacus
need information with brake D-17 series 4
something happened petal goes all the way down does not apply any braking on right side, has been ok for years, just happened all at once. took a quick look block that rod screws into for adjusting is loose indicating something with lower brake has something broken in lower rod area. looking for easy way to get to it to take a look without pulling axel housing.
series 4 factory 3 point hitch dual remotes, all the hyd. valves connect together mounded to axel and fender making this look like a major project. asking for any suggestions of best way to approach this project.
