Rear axel seal on D10
You need to remove the axle, remove the bull gear pan, remove the cap on the outside of the bull gear housing, remove the nut that was under the cap, loosen the internal axle nut. put a puller on the hub and pull won't be easy, as the axle comes out keep loosening the internal nut. Don't let the bullgear hit the floor. Not an easy job.
