How to shim up wheels
dhermesc
We have replaced the rims on our D17 Series IV with rims off another D17 (unknown). We finally installed the rims and wheels on the tractor and we now get a popping noise from the rims as the spinouts appear to flex during cornering or shifting of the "load" from pulling to holding back. Do you shim these? Drill and install more spinout stops?
You can use a different spot...it"s likely not as worn as the current one. Should have built up the worn one with weld when the tire was off.
