TractorLinks.com
Show Parts for Model:
185 plug
Jim Phelps
03-13-2018 05:27:17
Can someone tell me what type of thread is the plug for the hydrualics on a 185. The thread is really deep and wide. can't find anything like it at rural king or any of the shops around town.
DrAllis
03-13-2018 07:21:05
 Re: 185 plug in reply to Jim Phelps, 03-13-2018 05:27:17
It's directly underneath the seat.....above the drawbar.
Jim Phelps
03-13-2018 07:58:31
 Re: 185 plug in reply to DrAllis, 03-13-2018 07:21:05
Thanks
Traditional Farmer
03-13-2018 06:15:19
The rear end plug is also the odd plug I have never been able to find anything that fit exactly,when I put a crossover line on my 180 because the seal went out between the trans
and rear I had a machine shop drill the plug and weld in a 1/4" nipple.
DrAllis
03-13-2018 05:34:59
There are TWO drain plugs for the hydraulic system. The one that points straight down to the ground is 1/2" pipe threads (very common) and the one pointing straight ahead on the PTO box is the odd one. I can't tell you what it is, but it might be coarse thread bolt ?? with a gasket used to seal it.
Jim Phelps
03-13-2018 06:31:21
 Re: 185 plug in reply to DrAllis, 03-13-2018 05:34:59
Here is my question, like the gentleman above my seal went out and for the time being I was looking at putting in a cross over line. I only see two plugs the one straight down is 1/2 pipe, I thought that came out of the tranny? And the odd plug coming out of the front. Thanks.
Traditional Farmer
03-13-2018 06:42:43
 Re: 185 plug in reply to Jim Phelps, 03-13-2018 06:31:21
There is also an odd plug in the rear,you need to drain all the oil out and then run a hose from the rear end plug to the 1/2" pipe plug in the trans.Fill with hydraulic oil.
Jim Phelps
03-13-2018 06:55:13
 Re: 185 plug in reply to Traditional Farmer, 03-13-2018 06:42:43
So I don't have to use that odd plug in the front. I need to get back under and look for the other plug.
