Oil Pickup Tube
YTSupport
Administrator
Staff member
Any opinions on using thread locker or at least thread sealer on the oil pickup tube where it threads into the block? This is on the G-149 block. I've disassembled three of these now, and all of the tubes were extremely tight.
I've only ever overhauled probably 6 or 7 of those over the years and always left that tube alone. If it was tight.....leave it be. I had no problem cleaning the passages with it installed. So, to answer your question, I guess I'd lean towards a thread locker so it could never move.
I had to remove it for the machine shop to accept it and it was tight. Thanks, that confirms what I was wanting to do.
I never used thread lock. I just tighten the snot out of it going back in. I take them out with a 10 inch pipe wrench and what ever length of cheater pipe it takes. I should say took out. My tooking out stuff has come to an end.
Drop your rocks I know most would use taking out.
