How many more parts do I need besides the $860.00 Torque Generator? I have researched this on this site & others & it apears I also need a $71.00 Port Block kit (hose manifold) in order to hook the hydraulic hoses to the PS unit. Also, do I need a bracket for the PS unit? Can this be bought or need to be made? A Steiner tractor parts tech told me that I also will need a $223.00 priority valve. Do I need this? I can see a hole in both shafts on the Char Lynn unit, & understand that after cutting 10" out of my steering shaft, I need to drill a hole in each end also. What is used to connect the steering shaft ends to the PS unit? Are there some collars involved to connect them together with roll pins? Do the roll pins come with the unit or do I need the diameter & length & buy them? Your help is really appreciated.
Thanks, Ken C.
Thanks, Ken C.
