CA trans oil leak
pat sublett
Having trouble with Transaxle oil leaking on CA. I replaced axle seals but it appears that I have leaks on both sides where the axle housings bolt to the Trans. Any advise?
Did you put sealer between the shims on each side. Originally they used paper shims in between the metal shims, other wise they will leak.
I replaced both right and left, in the transmission housing, when I had it apart, to rebuild the hand clutch, maybe this is a different set of seals you are talking about, but both axles had to be removed, if I remember correctly.
