Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: D262 Problem, Buda 273 engine block
Mike(NEOhio)
02-06-2018 12:36:53
The Buda 273s are cast in block cylinders, not wet sleeve. You may be able to do it with a 230 block. Also, Buda sleeves have the seal ring on the sleeve, ACs have the seals in the block. Don't let anyone tell you they're the same. Some parts are, but not all. Just finished rebuilding a 230, picture of a Buda sleeve and what the parts supplier said was the right one. Is it the same as your AC?
Stefan
02-06-2018 13:36:24
 Re: D262 Problem, Buda 273 engine block in reply to Mike(NEOhio), 02-06-2018 12:36:53
Hi
My 273 engine have no sleeves at all. What im looking for is, let the work shop to press in dry sleeves in the 273 to narrow the bore. Maybe i have solve the sinking sleeve problem and can use all the new parts from the 262 engine on the 273. It vill be a "buda d262"
// Stefan
Mike(NEOhio)
02-06-2018 13:59:58
 Re: D262 Problem, Buda 273 engine block in reply to Stefan, 02-06-2018 13:36:24
The sleeve idea may work. The 262 is 4.375 stroke, 230/273 Budas were 4.125. You may have a clearance problem.
Stefan
02-06-2018 14:18:07
 Re: D262 Problem, Buda 273 engine block in reply to Mike(NEOhio), 02-06-2018 13:59:58
Yes mybe, that is what I are afraid for.
I will swap also crank, rods and pistons.
If the distance between crankcenter and top deck are the same, it would be perfect.
