TractorLinks.com
Show Parts for Model:
Re: D262 Problem, Buda 273 engine block
DrAllis
02-06-2018 10:23:47
I've never seen or worked on a 273 Buda. I am going to guess the block deck heights are the same or very close to the same. I am also pretty sure the crankshaft will swap just fine too. If the main bearing kit is the same between the two engines, for sure the crank will fit. A good machine shop here in the USA could look up the crankshaft centerline to deck dimension easily and then compare it to the Buda. I've heard of the 262 crank being installed in a 273 for more cubic inches, so I'm sure it's been done before.
Stefan
02-06-2018 13:41:29
 Re: D262 Problem, Buda 273 engine block in reply to DrAllis, 02-06-2018 10:23:47
Hi
Thanks for the answer.
Do you know any workshop in US who will know for sure if the distance from center of the crank to topp of the engine block are the same, d262 and d273.
// Stefan
