TractorLinks.com
Show Parts for Model:
D17 series 1 block heater
luke470
02-04-2018 11:33:18
Is there a place on an early D17 series one to install a block heater?
If so what size?
Thanks!
DrAllis
02-24-2018 15:40:40
 Re: D17 series 1 block heater in reply to luke470, 02-04-2018 11:33:18
Quoting Removed, click Modern View to see ***** That is the wrong way to do it, because now the temp sensor bulb isn't in hot water. The temp gauge will always read LOW when installed like that.
Brian in MO
02-24-2018 10:17:23
I was in a salvage yard last week and saw a d17 that had a block heater. They had used the block drain then went up to the temperature sensor where they put a tee in to use for a return line.
JMS/.MN
02-05-2018 13:03:37
Size depends on how long you care to wait to get it warm. Tank heaters typically come in 750/1000/1500 watt size.
DrAllis
02-04-2018 14:10:26
Tank type heater using the block drain to feed it and cut the bypass hose in two and install a TEE for the hot water to go into. Either that or a lower hose heater. This is for a gas engine.
Aaron SEIA
02-04-2018 12:52:57
I don't think so. You could check on a lower radiator hose one.
AaronSEIA
