Weight of WD
Earle(NC)
New User
Can someone give me an idea of what a stripped down (no hyd/lift) WD with wide front end, not loaded tires, would weigh. Thanks in advance
My 1957 WD-45 wide front with 14.9 x 28 dry front and rear tires weighs 3600 lbs. I've pulled it a couple of times and that's what two different scales have said.
I scaled my WD 45 over a certified scale when I got it and it weighed 3880. It had no weights or fluid in 14.9x28's with wide front end but had PTO and no belt pull.
I've seen WD's in the 3500 lb class at tractor pulls that's 3500 lbs including the driver,they were all NF and single wheel fronts though.WC's can go into the 3000 lb class and a
WC in the 3500 will out pull a WD almost every time.
