WD instrument pod
jerkus730
I've been trying to find a decent instrument pod for my WD. So do I have this right? The 45'S had a key and the WD'S didn't?
Yes, basically, the WD had a magneto grounding push/pull switch on the upper part, next to the light switch. The WD45 had a key switch on the lower part.
Later model WD's had battery ignition as standard equipment, so they were exactly the same as the WD-45.
