HP on 66 D15
RDobbs
I have a D15 series 2 Allis. Assuming it is stock, how
much HP does it have. I was told 4O hp. Its a 66 or
67 model wide front.
Tested - PTO @ rated engine speed 46
PTO @ rated PTO speed 42
Drawbar, maximum 38
With the D15II AC pushed the little engine which started out in the AC B about as far as they could.
I hope you can make sense of my listing. No matter how I try to do it, even after viewing my preview, this site jams everything together.
I'll try it again.
PTO HP @ rated engine speed 46.
PTO HP @ PTO speed 42.
Maximum drawbar HP 38.
The early D-15's were only 40 HP and could not come close to replacing a good WD45 on a plow. The series 2 D-15's were 46 HP and came closer to the WD45, but still would never out work one on a 3-16's plow. Much nicer to operate, but you needed a D-17 to replace a WD45.
(quoted from post at 20:19:38 01/09/18) The D-15 series 11 is a complete differant block than a B or C, the series 11 has a 5 main brg block ! ATTENTION !! THE D-15 SERIES 2 GAS BLOCK IS NOT 5 MAIN BEARINGS. IT HAS 3 MAIN BEARINGS JUST LIKE B-C-CA-D10-12-14-15. IT ALSO LOOKS JUST LIKE D-14 AND EARLY D-15 BLOCKS BUT IT IS BORED A LARGER DIAMETER FOR THE LARGER SLEEVES.
