TractorLinks.com
Show Parts for Model:
HP on 66 D15
rdobbs
01-05-2018 10:35:01
I have a D15 series 2 Allis. Assuming it is stock, how
much HP does it have. I was told 4O hp. Its a 66 or
67 model wide front.
DrAllis
01-10-2018 05:25:29
 Re: HP on 66 D15 in reply to rdobbs, 01-05-2018 10:35:01
[quote="CVPost-FastFarmall"](quoted from post at 20:19:38 01/09/18) The D-15 series 11 is a complete differant block than a B or C, the series 11 has a 5 main brg block ! ATTENTION !! THE D-15 SERIES 2 GAS BLOCK IS NOT 5 MAIN BEARINGS. IT HAS 3 MAIN BEARINGS JUST LIKE B-C-CA-D10-12-14-15. IT ALSO LOOKS JUST LIKE D-14 AND EARLY D-15 BLOCKS BUT IT IS BORED A LARGER DIAMETER FOR THE LARGER SLEEVES.
DrAllis
01-05-2018 17:18:37
The early D-15's were only 40 HP and could not come close to replacing a good WD45 on a plow. The series 2 D-15's were 46 HP and came closer to the WD45, but still would never out work one on a 3-16's plow. Much nicer to operate, but you needed a D-17 to replace a WD45.
Bob Bancroft
01-05-2018 12:08:52
Tested - PTO @ rated engine speed 46 PTO @ rated PTO speed 42 Drawbar, maximum 38
With the D15II AC pushed the little engine which started out in the AC B about as far as they could.
FastFarmall
01-09-2018 19:19:38
 Re: HP on 66 D15 in reply to Bob Bancroft, 01-05-2018 12:08:52
Bob Bancroft
01-05-2018 12:13:28
I hope you can make sense of my listing. No matter how I try to do it, even after viewing my preview, this site jams everything together. I'll try it again.
PTO HP @ rated engine speed 46.
PTO HP @ PTO speed 42.
Maximum drawbar HP 38.
Bob Bancroft
01-05-2018 12:17:08
 Re: HP on 66 D15 in reply to Bob Bancroft, 01-05-2018 12:13:28
Also, I'm assuming gas, as this was by far, the most popular version.
old
01-05-2018 10:57:00
As per my Neb. test list gas is 40HP diesel is 36.5 and LP is 37.40HP
rdobbs
01-05-2018 15:11:01
 Re: HP on 66 D15 in reply to old, 01-05-2018 10:57:00
Thanks guys for all the info. It is gas.
