WD45 throttle rod ,adjuster fittings
RalphWD45
I have misplaced the two adjusting fittings, that tighten down, on my two piece throttle rods. that run on the right side of the engine, from the govener to a bell crank, by the gas tank, and then on back from the bell crank , back to the hand throttle, at the steering post. These two fittings, fit in the bell crank, and accept the 1/4 " throttle rod, and the 1/4" govener rod. The throttle speed is set by adjusting the length of the 1/4" rods by tightening the fittings , on the rods, to the desired speed. I have looked in Stiners catalog, and Tired Iron's catalog, and can't find them. Does any of you guys know of a source for these? This is a 1955 AC WD45., and is ready to come out of the shop, and go to work!
Is this what your looking for? If so DJS tractor parts has new ones listed.
Thanks so much D Beatty! That is exactly what I am needing! I have never known about DJS tractor parts, till now. They are closed, for the holidays, till the 2nd, but will be ordering from them Tuesday. THANKS AGAIN GUY!
I have found things like those at a farm and home store and or a good hardware store
I was in O'Reilly's this morning and saw those in there HELP area as I was looking for push nuts
