WC Clutch Question
I think I know how I am going to tackle this, but here is my question. I am converting a hand crank unstyled WC and putting a newer starter clutch housing on the chassis. When I joined the engine back onto the clutch housing I can't get the throw out bearing far enough forward to engage the spring release levers on the clutch. Attached is a picture. The throw out bearing is barely touching the release levers and just seeking advice before I start back at it. Thank you.
sure looks that way -
<a href="http://s33.photobucket.com/user/Joecdeere/media/1941%20WC/wcpics150.jpg.html" target="_blank">
</a>
should be 1/4"
<a href="http://s33.photobucket.com/user/Joecdeere/media/9A45D7DA-7DA3-497A-8892-1872401C7FBF_zpsd7imvfai.jpeg.html" target="_blank">
9A45D7DA-7DA3-497A-8892-1872401C7FBF_zpsd7imvfai.jpeg" border="0" alt=" photo 9A45D7DA-7DA3-497A-8892-1872401C7FBF_zpsd7imvfai.jpeg
</a>
Throw out bearing appears to be on backwards and the part of the bearing that spins in not on the pressure plate fingers so the bearing cannot work
