7040 weights
Dieseltech
Location
Akron, Indiana
Have an AC 7040 with the eight rail PAVT 18.4 X 38 tires, cast centers. Also has one weight bolted to each wheel on the inside. The owner's manual I have shows a photo of a tractor with three weights on the inside, but I have not found anywhere what each one weighs. Parts list I have does not list how much either. Anyone have sales info on what they weigh? Have the weight amount for the front weights and brackets, but nothing for the rear.
The one-piece inner weights I have used are 400 lbs each. They are nearly the same size as the cast rear wheel center.
Dr Allis may be correct ,however I always thought they were 450 each. The 7040 I had for 7 years had just one and worked well. my 7060 has 2 but also used to have fluid. It is considerable stronger than the 7040 and at times I miss the fluid which was about 1100lb in each wheel. When I got my 8070 I put three inside on each wheel.
