TractorLinks.com
Show Parts for Model:
Allis Chalmers loader.
Cjrpr
11-08-2017 14:46:47
Anybody know what model number this loader Is? Looks like it had a trip bucket at one time and someone made it hydraulic bucket. One of the lift cylinders needs to be rebuilt because it's leaking bad and I need to figure our what this is to get the correct parts. Thanks for any help.
Joe(TX)
11-21-2017 16:31:17
 Re: Allis Chalmers loader. in reply to Cjrpr, 11-08-2017 14:46:47
It would help to know what the loader was made to fit. WD, D14?
JMS/.MN
11-08-2017 20:54:04
Take the cyl to a hyd shop- they"ll measure the cyl/seals, and figure it out for you.
steve(ill)
11-08-2017 17:30:04
Many of the loader companies did not make the cylinders, they bought them from others... WE have a CASE 530 and the cylinder packing/ seals are "generic"... Normally you can get the cylinder ID diameter ( piston diameter) and the rod diameter, then buy a "generic kit" with several parts for rebuild...... you might pull it apart and look first.
Cjrpr
11-08-2017 14:48:45
Trying to figure out how to add a photo. I thought I did. Guess I didn't do it right.
Cjrpr
11-08-2017 14:59:04
 Re: Allis Chalmers loader. in reply to Cjrpr, 11-08-2017 14:48:45
Sorry guys. Can't seem to get the photo uploaded.
YTSupport
11-12-2017 07:13:56
 Re: Allis Chalmers loader. in reply to Cjrpr, 11-08-2017 14:59:04
The photo is probably oversized in it's filesize, posting photos on Modern View is more forgiving, but there is still a limit of 2MB file size. On classic, it's 300KB. If you email it to me, I will add it to the post.
To take a stab in the dark, if it's a 50s trip bucket with round tubes, it will likely be a Freeman manufactured loader. Those normally have a plate riveted into the left front upper arm which will be faded, but punched numbers will be seen on the lower right and left corners. The lower left number is the model, and the lower right number is the serial number.
