WD45 bolt into WC
WD engine is the exact same engine as the WC engine. The WD45 will also bolt right on with no problems plus will give you a bit more HP
WC and WD were 201 cu in engines....WD45 was a 226, all will bolt in. So will a D17,or Model E Gleaner combine, with some mods.
