john from Ontario
I have an Allis B with Mag. and hand start. It misses on #4 cylinder, but I found that if I partially close off the choke it will run on all 4 cylinders. I have replaced wires and plugs, checked for spark, got good gas flow out of the carb, and cleaned the carb (didn't do much disassembly). The compression is very low on all cylinders, about 40 psi. The engine does not burn oil or smoke and there don't appear to be any broken valve springs. I don't mind doing necessary repairs, just want to zero in on what might be wrong. Thanks for your help. You guys have helped me a lot over the years.
