d17 starter
Do all of the d17 gas tractors from 1957 to 1967 use the same starter? What would cause a starter to not come out of the housing, can only pull it out about 3/4 of a inch can rotate the starter to the oil pan and back to the frame rail.
All D-17 gassers use the same starter. If you are removing it because of a starter problem, I'd suspect the nose cone might be broken ?? You'll have to use a pry bar or maybe start to disassemble it in chassis. I've never had one I couldn't get pulled out of there by some method.
Could as DR says or it could be simple rust so working it around some and even some ATF or other such lube may help. Some times they can be bears to pull out due to having been on the thing for decades
