Hi guys, Im new on here and struggling with mt tractor. I have a 1950ish wd45 motor in a 1950ish cleat track dozer. It started running a little rough last fall plowing snow. I first thought i might have got some water in fuel so i drained tank and cleaned the carb. After doing that it still was not right so i was thinking possible ignition issues.The ignition had been changed over to 12 volt before i got it. I have had it for 10 years and has always ran good. I replaced plugs points condenser rotor and cap and coil. It started right up and runs good for short period 15-30 minutes then it starts sputtering and then dies. I check the spark at coil and seems to be shinny silver colored and not blue. If i take rotor cap off and gently scrape points with knife blade it will fire right back up for the 15-30 minutes. It is like the points are getting build up on them. I have them set at .020 The original coil i took off had been painted over so i could not tell exactly what it was, but looking on this site people are using the NAPA IC14SB so that is what i put on it. I have read on here about needing a resistor or not for that coil. I do not have a resistor in my wiring anywhere and not sure if the IC14SB has one built in or if i even need one? Hopefully you guys can give me some insight on my issue... Thank You
