steve-in-ga
My dads AC 5040 has developed a significant leak (dripping pretty bad) from the bottom backside of the injection pump. The leak appears to be coming from what looks
like some sort of stubby little rod with a washer on the end of it and cotter pin holding the washer on. The rod that you pull to shut off the fuel looks like it runs around the
rod that is leaking. I can use a screw driver to gently push on the rod that is leaking and it is loose and when I move it it really starts pouring fuel. I used a wrench to try
and tighten the nut that is hold the leaking rod and I cannot seem to stop the leak.
Any help is appreciated stopping this leak if only temporarily.
thanks,
Steve
thanks,
Steve
