I couldn't get lights or amp meter reading last time I ran my C. I checked the ground and it looks clean. Pulled the 3-way. Cleaned all the connections and sprayed LPS into the switch. The fuse and resister are good. I get continuity from the "B" terminal to the "S" terminal with the selector in the center ( 3 o'clock) position only. I assume I should get it when the switch is in the 5 o'clock also. Correct? Can these switches be taken apart easily or are there a lot of small parts that go flying? Also, there is a flat spring under the resistor with about a 1/8" tip that goes into the switch housing. Mine drops into the housing only when the selector is in the 1 o"clock position. I assume it breaks the circuit. Yes?
Thanks.
Thanks.
