I have a 1944 Narrow front with short steering shaft at pedestal.
I have the segment gear that is held onto the short shaft with a set screw from the side and it is keyed on shaft I think.
Set screw and jamb nut are off, I have applied some heat - But cannot get gear off inside the housing - very little room to work.
Any ideas how to help it off, I believe it should just slide off - it was loaded with grease so no rust in there.
Need to replace bushings.
My final attempt will be cutting the shaft and re-welding once bushings changed. Really don't want to do this..
HELP.....
Thanks in advance..
HELP.....
Thanks in advance..
