Belt pulley rod diameter
YTSupport
Administrator
Staff member
For those of you who have the D14, D15, or D17 belt pulley actuating rod, could you measure the diameter stock AC used. I have to fabricate one because I have the pulley, but I don't have the rod. It appears to be 3/8s stock since there is little space left in the 7/16s dash slot for it, but I'd like to confirm before starting on it. I would also like to know about how much of the bare rod shows through the dash when it's disengaged. I'm guessing about a 1/2 inch from ones I've seen.
Thanks in advance.
Could you maybe us a set of calipers to measure how big the diameter of the hole is in the lever?? That should get you the rod size. I know that is how I would do it on this D-17 I have if I get a belt pulley set up for it
(quoted from post at 22:47:07 10/02/17) Could you maybe us a set of calipers to measure how big the diameter of the hole is in the lever?? That should get you the rod size. I know that is how I would do it on this D-17 I have if I get a belt pulley set up for it
Yes, that's where I came up with 3/8s partially. I just wanted a firm measurement from someone else with the real AC part. Your D17 should be the same as what mine should be.
My D-17 only has the lever in the torque tube so it has no rod going to the dahs. Shoot I have never see a D-17 with a belt pulley on it let alone the rod it self
I see, I thought you had the dash rod, but you have the case lever itself. I think all of them had that, even on the Series IV.
I'm guessing you're about right on the 1/2 inch. It wasn't much. As I recall, there was a knob, maybe 1.5" in diameter, which was fairly flat, you could just get your fingers around?
Thanks to both of you. 3/8s it is. It's a press fit through the lever (which I will take it down just slightly) and a perfect fit through the dash hole, slides easily.
I'll use a WD45 PTO knob for now since it's a 3/8s fine thread. Should be able to find the flat style through antique auto suppliers when I have time to research.
If you go back to my post the other day asking about the Belt pulley lever one of the guys there said something about the series 4 D-17 not having the place for the belt pulley so if he is correct the series 3 was the last one to have that option
Yes, as far as the parts manual goes, the Series IV belt pulley controls were gone, but the torque-tube opening was still there and in use if you look at images of the right side of the Series IV. I was guessing a gear similar to the belt pulley drive gear would still be present to drive the right side-mount hydraulic pump. Otherwise I couldn't see how it could be driven.
