i finally got my wd running what a mess , now we have a dist style ignition, new everything there, the broken starter nose repaired, and on that i found a actual real talented welder, for around here thats saying something, we can all weld pipe fence and farm implements, but to be able to weld cast and make it look factory thats something. now besides numerous hydraulic leaks after i changed the fluids, the hand clutch is loose as a goose, i have a parts manual, but it looks like a threaded bolt? coming out of the side of the transmission housing is moving, how much of a problem is it to mess with that? or should i leave it alone,
