Tim Steele
I use my Deutz for raking hay 99% of the time. It stays hooked to the rake all year. I was raking the last bit of hay and noted a loud whine coming from the area near the hydraulic receptacles. I stopped immediately and checked for a broken hose or massive leak suspecting the whine was the pump low on fluid. Reservoir was full no leaks. I engaged the PTO and the noise quit so I finished raking hay and drove it back to the house. I took the rake off and hooked up my 16 foot batwing bush hog and discovered upon engine start that the PTO was engaged with the handle selected to disengaged and the loud whine was back. I engaged the PTO and the noise went away. I bushogged 10 acres and other than not being able to disengage the PTO everything operated normally. I unhooked the bush hog and put the tractor in the lean to off of my corn crib where it spends the winter. I verified the linkage is moving. Can anyone shed light on this? I have three other tractors and ordinarily don't use the Deutz for anything but raking hay and my rake doesn't need PTO so it won't affect my operation but I am curious as to what happened and don't want to hurt the tractor.
In my quest to figure out the noise I also discovered a handle on the back of the tractor just above the hydraulic reservoir and dipstick that I have no idea what it is for? I tried to move it and it didnt move? I will take a picture of the handle tomorrow and post it. Anybody here have any ideas? Thank you all in advance. I figured since it is now Deutz Allis it would be OK to pose this query here...
