alliumdream
New User
While working on my G's I keep running into this problem only with the fine threaded parts. NC nuts and bolts screw in fine. For example, the studs/nuts and bolts that connect the PTO body to the transfer case/bell housing. I ordered a thread ID gauge but in the meantime does anyone know what thread standard these are?
Another place I had the same problem is the 5/8 (i think) stud that connects the drawbar on the bottom of the tractor. Also the bolts that connect the drawbar bracket to the engine block.
Thank you guys for any help.
