Model 200 semi mount plow question
All,
Looking at a 200 semi mount 3 bottom reset plow. Is there any way to modify the mounts so it fits on a wd45?... Seems like messing around but someone must have done it?
You must be referring to a model 2000 series 3-16's trip bottom ?? If you worked over the hitch to be a snap-coupler type, that plow is too heavy and too far behind for a WD-45 to be able to do a respectable job pulling it. In fact, there'd be soils it flat out wouldn't pull it.
Adam where are you located? I have a 3x16 snap coupler slat bottom plow that would work behind your WD45. I am
in south central Iowa. CHEAP. Front bottom has 2 slats broken but I have used it on many acres as is.
