Tractor giving me trouble
Farmer737
New User
I was raking hay my wd45 kept acting like it was running out of gas. I took carb apart cleaned and replaced now it acts like you turn the key off. Need some help with this one
There may be some thing in the gas tank that floats over your gas outlet and floats away when the engine shuts off. I had that happen on my WD 45. Randy
One time I had a bad toggle switch that was a cheap one. (Intermitten power) It
acted the same way, like bad fuel. If you still have the original "key" switch,
try bypassing it.
