Allis bush hog
Olfolks
Hello all, I have an older allis 6 foot bush hog
It needs new blades but has no model number or serial
Number in it. It has 2 large blades on the bottom and
2 smaller ones above those . Can anyone give me a
Part number for the blades and or bolts thanks olfolks
Hello olfolks,If indeed your rotary cutter is an allis chalmers.then you should contact brenda at sandy lake implement explain to her what you have and she will do her best to help you with parts and other info.Best of luck.if you can, post some pics of this machine.I am sort of an allis chalmers nut. Barney sandy lake implement phone # 888-252-0656 they specialize in allis chalmers equipment
Barney,
Thanks for the info . I am almost 100% sure it is an allis
it belongs to an older friend of mine and he wouldn't use anything but an allis hog just because of the twin blade set up
it does a really fine job of mowing and when the blades were good it would mow a yard as good as most lawn mowers
