Bearing race on 53 CA
Topsarg
Anyone have any suggestions on removing this bearing race on my 53 CA Pulling Tractor...
The final drive will need to be removed from the transmission. Then brake bands removed and the brake drum removed so the shaft can come out the opening in the picture. I bet you already knew that and was hoping you were wrong!
It appears that I'll need a number for the bearing and race..this one is not readable.. Any Help? I can make out USA on it but that's it..
Is the end broke off the pinion gear at 9 o clock in your picture. Looks like pieces of the bearing in the gear teeth.
